Review the following restrictions, limitations, and behavioral characteristics that are associated with Fabric Extend.
Tunnel Source IP
Fabric Extend supports the tunnel source IP address using a brouter port interface, a CLIP IP, or a VLAN IP.
For the 16-port and 24-port 5320 Series switches, you must configure a route-map policy to suppress IS-IS redistribution of the FE tunnel subnet:
Tunnel Failover Time
With IS-IS interface default values, tunnel failure detection can take up to 27 seconds. You can reduce the IS-IS interface hello timers to speed up logical link failure detection, but be careful to avoid link flapping due to values that are too low.
If the number of IS-IS interfaces on a node is greater than 100, it is a good practice to set the hello timer not lower than 5 seconds.
ACL Filters over VXLAN
IP filters configured to match IP header fields in the headers of VXLAN encapsulated packets, work only when the switch acts as a transit router and does not participate in the initiation or termination of VXLAN traffic.
VLACP
VLACP is not supported over logical IS-IS interfaces.
CFM CCM
CFM Continuity Check Messages are not supported over logical IS-IS interfaces.
CFM traceroute and tracemroute
If CFM packets transit over a layer 3 tunnel (that is the CFM packets ingress a Fabric Extend layer 3 core tunnel and egress through another layer 3 core tunnel), the transit SPBM nodes do not display as intermediate hops in the output for CFM l2 traceroute and l2 tracemroute.
This is because the CFM packets are encapsulated in the outer layer 3 header as part of VXLAN encapsulation, and the transit SPBM nodes cannot look into the payload of the VXLAN packet and send a copy of the CFM packet to local CPU for processing.
CFM L2 Ping
CFM Layer 2 ping to MCoSPB source mac is not supported and can fail if they are reachable through a Fabric Extend tunnel.
Switch-based MAC Security (MACsec) encryption is Layer 2 so it cannot be used with Fabric Extend IP, which is Layer 3.
MTU Minimum in Layer 2 Pseudowire Core Networks
Service provider Layer 2 connections must be at least 1544 bytes. In this type of deployment the tunnels are point-to-point VLAN connections that do not require VXLAN encapsulation. The default MTU value is 1950.
Logical IS-IS Interfaces
Layer 2 core and Layer 3 core logical IS-IS interfaces are not supported on the same switch at the same time.
Fragmentation and Reassembly
There is no fragmentation and reassembly support in Layer 2 core solutions.
Layer 2 Logical IS-IS Interfaces
Layer 2 logical IS-IS interfaces are created using VLANs. Different Layer 2 network Service Providers can share the same VLAN as long as they use different ports or MLT IDs.
MTU Minimum in Layer 3 Core Networks
Service provider IP connections must be at least 1594 bytes to establish IS-IS adjacency over FE tunnels. The 1594 bytes includes the actual maximum frame size with MAC-in-MAC and VXLAN headers. If this required MTU size is not available, a log message reports that the IS-IS adjacency was not established. MTU cannot be auto-discovered over an IP tunnel so the tunnel MTU will not be automatically set. The default MTU value is 1950.
IP Shortcuts
The tunnel destination IP cannot be reachable through an IP Shortcuts route.
Important
Important
If you enable IP Shortcuts and you are using the GRT as the tunnel source VRF, you must configure an IS-IS accept policy or exclude route-map to ensure that tunnel destination IP addresses are not learned through IS-IS.
If you enable IP Shortcuts and you are using a VRF as the tunnel source VRF, this is not an issue.
Layer 3 over Layer 2 Limitation
Port Mirroring Resources
Port mirroring resources are limited to four ports simultaneously (where each mirroring direction counts as one). For example, if two mirroring ports are designated to mirror both ingress and egress traffic then all four mirroring ports are consumed.
Port mirroring shares these four resources with other applications such as port mirroring RSPAN, Fabric Extend, Application Telemetry, IPFIX, and ACL with mirror action. Each one of these applications consumes at least one port mirroring resource. (port mirroring RSPAN consumes two if you configure both Ingress and Egress modes.)
Important
Important
To enable any one of the preceding applications, you must have at least one free mirroring resource. If all four port mirroring resources are already in use, the switch displays a Resource not available error message when you try to enable the application.
